rear defroster question
Old Jun 12, 2003 | 08:31 AM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
ok so i took my whole rear internal panels out to re paint them! (looks like new).. and I found the wire for the other strut that works the rear defroster!
so i'm excited now i havent had rear defrosters ever and when i hit the button... the light goes out then if I hold it I get a pretty lud clicking noise from what sounds like the passenger side dash...
maybe from the heter core? any ideas on whats wrong?
Old Jun 13, 2003 | 11:48 AM
Vader's Avatar
There is a relay panel in front of the right side dash. It contains the power antenna relay, RW defroster relay, and other components. I'm guessing you have a failing relay or connection issue there.
Old Jun 13, 2003 | 12:07 PM
TransAmTBI's Avatar
Engine: 305 TBI
thanx vader! i was getting worried that noone could help me... in front of the right side dash? how do i get to it from underneath? or should i take apart the guage cluster where the switch sits into?
Old Jun 13, 2003 | 09:56 PM
TransAmTBI's Avatar
Engine: 305 TBI
do ytou think this relay would also cause these other problems... sometimes my tach jump around but the actuall rpm stay normal... when i turn the fan for my defrosters on to max... it shuts off but if i turn it back a notch it comes on full!
Old Jun 13, 2003 | 10:53 PM
Vader's Avatar
If you remove teh lower dash trim panel you might be able to see the relays. I had to remove the dash panel itself to access that relay panel.
As for your other issues, you may have a power connection or ground problem feeding the controls, or a completely separate problem with the fan switch. The tach may be a connection problem again, or the tach filter failing.
Old Jun 14, 2003 | 01:20 AM
TransAmTBI's Avatar
Engine: 305 TBI
thanx vader i'll get right on to fixing this
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
