Power Antenna Help
Old Jun 18, 2003 | 07:39 AM
JayHodge's Avatar
Car: 1987 Iroc-z
Engine: 5.7L 350
Transmission: 700 r4
Power Antenna Help
Okk my power antenna was disconnected when i bought the car, the 3 wires green gray and white were cut on passenger side... so i hooked them back up and now the motor just constantly spins...i found the wire that retracts the antenna has been broken in 2 inside but thats not the major problem....
How do i get the motor to stop pulling in, as soon as i hook the wires up, it automatically retracts and just keeps spinning around and around retracting?? What causes it to know that the antenna has been retacted all the way?
And also which wire hooks up to my cd player if one does, and what wire do i connect it to my cd player? thx
camaro 87 iroc 350
jayhodge
Old Jun 18, 2003 | 04:57 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
A pink wire hooks to the antenna wire.
The spinning could be caused by the antenna mast bein stripped. If the teeth on the mast are gone, then the motor will keep spinning trying to pull it down. See if the mast moves freely up and down.
There is some sort of limit switch inside the motor that senses when the mast is down. If teeth are missing, then the motor cant pull the mast all the way down so the motor will continue running.
Matt
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
