82-86 vs. 87-92 motors
Old Jun 24, 2003 | 12:32 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
delete
thanks
Old Jun 24, 2003 | 01:57 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
oops
Old Jun 24, 2003 | 02:03 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
hmmm
Old Jun 24, 2003 | 02:08 PM
deadbird's Avatar
Engine: TPI 305/ v6
Considering you have a post just below relating to your headlight motors.. you'd think I would have figured that out huh ?
82-4 and 85-6 all used the 3 relay system. I don't remember, but, I think there was a small revision to the housing/motor in 85-6. I don't know what it was though
87-up changed completely and started using a single headlight relay module that controlled both motors and in mounted on the firewall.
edit.. I just remembered this site. It has some good information about the lights (even though it's on a fiero.. they used the same motors)
http://home.t-online.de/home/O_Scholz/headlight.html
Old Jun 24, 2003 | 03:14 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
how can i figure that out if i have never seen any motors newer than 84 ?? i have no clue if they did change them let laone how they changed them
good site/page link there, cool
they make no mention of 82 83 motors, howcome ??
are they different from 84-86 also ?
thanks
Old Jun 24, 2003 | 04:18 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
I believe '82-'83 motors used 4 wires, then in '84 they switched to 3. They make no mention of the '82-'83 motors on the Fiero site cause there were no Fieros till '84.
Matt
Old Jun 24, 2003 | 05:59 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
oh, interesting, so we can assume 82-86 are all same then ?
i think it was three wire early and then 2 wire later, at least thats what i been seeing in searches i think
Old Jun 25, 2003 | 04:23 PM
Matto'85TA's Avatar
Yes, for the most part all '82-'86 motors are the same. With the exception that the number of wires may be different. That can probably be fixed by splicing wires into each other.
Just so you know: I heard the 4 wire thing from somewhere on these boards or from some retailer when I was going to purchase a new headlight motor for my car. I vaguely remember seeing a pic of a 4 wire unit or reading about it somewhere.
I have yet to see a '82 or '83 Firebird or Trans Am. So I believe there are 4 wires, but that may be wrong.
Anybody care to clarify this for me? I'd like to know for sure.
Matt
Old Jun 25, 2003 | 05:42 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
its 3 on early ones and 2 on later ones, no such thing as four wire motors
what i dont understand is why my driver side motor third wire is dark blue and someone spliced white wire to it, and pass side motor is white wire correct no splicing
https://www.thirdgen.org/techbb2/sho...ht+motor+wires
https://www.thirdgen.org/techbb2/sho...hreadid=126586
Old Jun 26, 2003 | 02:11 AM
biff85ta's Avatar
Car: 04 Vette
One of your headlight motors was probably swapped for a fiero motor which have different plugs but are otherwise direct replacements I should know I put firebird motors on my fiero when I had it.
Old Jun 27, 2003 | 03:02 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
the relay plug is same one the blue wire motor, but just has the separate third wire being blue,
so firebird motors third wire is white and fiero are blue, right ?
these two motors are completely identical in evetry way i can see except are reversed as far as output shaft placement, event he silver stickers with partnumbers are in same place and everything on both motors.
thanks
Old Jun 27, 2003 | 10:49 PM
deadbird's Avatar
Engine: TPI 305/ v6
Fast.. I can't much help you with the motor identity due to not owning a 'bird in your year range but, I can somewhat help you with wiring identity. Here's a general diagram of how your car "should" be wired (am I nice or what ... lol )....
Old Jun 28, 2003 | 01:31 AM
biff85ta's Avatar
Car: 04 Vette
thanks
That sounds about right but it has been about five years since I worked on the headlight motors on my fiero but I know the plugs are different but being the fiero unit has one wire on a seperate plug and I belive it is blue but I remove the cover from the motor compared where the wires where and spliced the accordingly.
Old Jun 29, 2003 | 12:00 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
thanks guys, i appreciate it
Old Nov 13, 2005 | 12:10 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Back from the dead...
Is there an easy way to wire up 3-wire headlight motors to a 2-wire control box / harness? Maybe a couple diodes or something?
-Craig
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
matthew911
Aug 12, 2015 09:38 AM
