Engine swap, no start
Old Jun 29, 2003 | 06:25 PM
bocci50's Avatar
I swapped a 305 with a 350.
Now I'm having starting problems.
I got the car started, it runs and then when trying again, the batteries dead. It won't hold a charge.
I replaced the battery and had the same problem.
I then replaced the alternator, put in another new battery and it
starts and runs for awhile and then when I go to restart it, the battery is dead again.
I also noticed that when I go to start it, it will click a few times and then start up. The starter has a new solenoid on it.
So, I've replaced the battery twice, the alternator and a new starter solenoid.
Any ideas?
Old Jun 30, 2003 | 05:48 PM
cfabe's Avatar
Sounds like a wiring problem, check your power and trigger wires to the starter, the alternator wiring, and all your grounds. I bet you forgot one of the grounds when you swapped the engine.
Old Jul 3, 2003 | 08:00 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
My guess is oine of the starter wires...Too bad you spent so much and you probably didnt need it!
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
