electrical problem headlights
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
well the previous owner obveusly didn't like his/my car and basically butcherd everything he touched...
so i'm stuck with headlights that don't work. I used a voltage meter and found no voltage going to the headlights so it's not the bulbs.
the turn singals don't work either but everything els does brake lights hazards backup lights.
I thought it was a short but could the headlight/turn signal switch just be bad? the windshield washer doesn't work either, but it's connected to the turn signal switch so..
the heater core was leaking uh real bad I mean you drive a block and allmost all the fluid is in the car... just fixed that what a PITA!
could it have leaked on anything causing a short? I checked all the fuses.
db057
Aug 11, 2015 10:11 PM
