need help with tach
Old Jul 14, 2003 | 10:15 PM
soon2B_best91RS's Avatar
need help with tach
motor swap tpi to carb and the tach isnt working and i would like to keep that then getting an aftermarket tach... any help? thanks
Old Jul 15, 2003 | 06:43 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
in the original harness, there was a plug going to the coil with a pink(or red) wire and a white wire, the red wire is the feed for the ignition, the white wire is the tachn it connects the the tach or negative coil terminal
Old Jul 16, 2003 | 11:52 PM
thank you, when i get some time to work on it i will have to give it a try, once again thanks
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
