Tach is goofy
Old Jul 27, 2003 | 04:19 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Tach is goofy
I put an LT1 in my firebird and my tach is misbehaving. The tach is fine at idle but drops to 0 during acceleration. The tach reads accurate as long as I am not accelerating. The tach worked fine before, but hasn't worked right since. Please help.
Old Aug 6, 2003 | 08:15 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
When you go changing stuff from stock... all hell can break loose lol... I'd just get an aftermarket tach!
Old Aug 6, 2003 | 11:46 PM
MrBill's Avatar
Does it have a tach filter on it? little silver can-looking thing with a wire out each end and a mounting/grounding tab.
Old Aug 9, 2003 | 06:50 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
No I do not have a filter, LT1s don't have one mounted on the coil. I have traced my problem to my fan wiring. The wire I used to power my relays is an ignition hot wire from my fuse box(pink/black). My tach works fine when my fan relays are disconnected. I can't drive my car without fans; so I need help isolating the problem. Is there something I could put inline, before the relays, to prevent this. Thanks for the help.
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
