Hot wire a 3rd gen?
Old Aug 6, 2003 | 11:28 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Hot wire a 3rd gen?
Im not stealing a car, mine was broken into and they ****ed up where I put the key in, it just spins free so I need to get my car started some how so I can drive it home (Im 3 hours away at school)... all the wires are exposed because they decided to take a hammer to my column and see what that revealed.
Kinda an odd request I know, but if anyone can help me it would save what it costs to rent a trailer. Thanks guys...
Old Aug 6, 2003 | 11:57 AM
badjuju342's Avatar
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
if the car is the '91 rs at the bottom of your post,the it has the VATS anti-theft.better call that wrecker and start scrounging the boneyards for a steering column.it won't allow the car to start if it doesn't get the resistor code(found on the ign key)
Old Aug 6, 2003 | 01:04 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
VATS should be disabled on the chip, Im running an ANLU 350 chip from a Caprice which didnt have vats...
Old Aug 6, 2003 | 01:21 PM
badjuju342's Avatar
Engine: ls1
ok,you will have to unplug harness from ign switch. the two reds are feeds from battery,the pink is ign (run),yellow is start,orange is acc1(heat,a/c),brown is acc2(radio,wipers).hope this helps.
Old Aug 6, 2003 | 01:28 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
Gee, when i asked the same question on the board, no one wanted to say anything whats up with that.....
Old Aug 6, 2003 | 03:18 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Awesome, thanks man. If only they could find my **** they took this fast lol...
Old Aug 6, 2003 | 08:13 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
Hey vats can be defeated easily. Measure the resistance in your key with a digital multimeter or something, then buy a resistor with the same ohm resistance and wire it in-line with the wire that goes to the key cylinder - it simulates the vats thingy on the key.
eightsixseven
Dec 16, 2024 01:50 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
reiderz iroc
Aug 13, 2015 04:57 PM
