can I use car battery to check headlight motor.....
Old Aug 6, 2003 | 12:23 PM
fakeyankee's Avatar
Car: 87 T/A
Engine: LM1 350
Transmission: 700 R4
Have the headlight motor from my 87 T/A out and disassembled. Everything appears to work properly. I have no voltage meter and was wondering if I could test the motor to see if the headlight motor is working by attaching jumpers directly to the cars battery.....or will this be bad for the motor ??? I believe the relay modual isn't working considering all the other posts i've read about headlight operations not functioning properly. Please help and advise !!!! Thanks !!
Old Aug 6, 2003 | 02:34 PM
badjuju342's Avatar
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
sure you can, the two wires coming directly from motor are what is called reverse polarity,i.e one wire shows12v in the up position and ground in the down position ,the other wire will do exact opposite of 1st.you basically need 12 v and ground to make anything electrical work and this is no different.
Old Aug 6, 2003 | 03:54 PM
fakeyankee's Avatar
Car: 87 T/A
Engine: LM1 350
Thanks BAD... So, I can jump one wire to the + side and the other to the - side of the battery ???? And if so......If I reversed the wires, will the motor spin the oppisite way ??? Not to good with elec. theory so sorry for the basic questions. Thanks !!!
Old Aug 6, 2003 | 03:58 PM
badjuju342's Avatar
Engine: ls1
that is it,perzactly. hey, electrical an be a nightmare,glad to help
Old Aug 6, 2003 | 04:19 PM
fakeyankee's Avatar
Car: 87 T/A
Engine: LM1 350
Great !!! Thanks for the help !!!!! Can I put you on my buddy list for electrical problems to PM ya anything i'm not sure about ???
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
