92 Z28 Foglights
Car: 1992 B4C/1LE Camaro
Transmission: T-5 W/C 5-Speed
92 Z28 Foglights
My 92 Z28/B4C did not come with foglights. What is the best way to add these? Is there a kit, or do I need to get everything off of another Z?:rockon:
First, if it is a B4C, it is an RS. Second, there is no kit available that I know of factory atleast. You can buy aftermarket fog lights or you can get everything off a Z28 like you mentioned.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I wouldn't even bother.... with a Z28 grill, and no fog lights, you'll have a nice blast of fresh (cold) air hitting you're radiator (if you're not running air condition that is)....
But if you like the effect, you'll need fog light's, hangers, fog light switch, and a small harness leading from the lights..... to the headlight harness (there 'should' be an extra connector somewhere by the front, considering that GM 'usually' (?) re-uses the same harness for every model V8 that same year)....
Take a look to be sure
Originally posted by m14mike
It is a RS/Z28/B4C/1LE just so you know....only 586 made and I've got one..
That rs in the picture will outhandle and outbrake any "real" z28 and do so with ac as well. B4C RS= the Z28 that should have been. I would love to have one while smoking Z28's through the corners, slowing down, and probably out accelerating them as well all in a measly RS.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
not telling you what to do or anything...but why add foglights to such a rare car? Even if you install a set of factory replacement 85-92 IROC/Z28 foglights....that would probably even drop down the value of the car.....if it were me....I'd leave it alone.
Engine: 5.7
my brothers white 87 Z28, my black 1991 Z28, and "Lefturn1LE's" 1991 Z28 with te 1LE option. Only 175 built with the 5.7's....no foglights here...pretty much untouched...VERY rare...
Sorry about saying it was a Z28...It is not on the RPO codes, and the only thing "Z" about it is the grill, however my title does say Z28. Not sure how that mistake was made.
blackz281le
Jan 11, 2016 07:51 AM
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
