LS1 harness vs LB9 harness
Old Aug 9, 2003 | 02:16 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
when swapping in an LS1 what mods have to be done to either harness to have it all work. i want to keep my vats and SES light. is the LB9s engine harness seperate from the rest of the cars harnesses, the lights for instance? i will be using ALL autometer gauges so im not worried about that. is it possible to use the whole 4th gen harness or what.
Old Aug 9, 2003 | 06:55 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I can't help with the LS1 part, but the engine harness is seperate from the rest of the car. The headlight harness will remain uncut and unaffected in the swap. The connection for vats and ses are under the dash. I do believe tha LS1 use a different version of vats than third gens. I hope this helps.
Old Aug 10, 2003 | 12:28 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
thank you.
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
dbrochard
Sep 19, 2015 08:13 PM
timonator
Sep 17, 2015 06:57 PM
gta892000
Sep 16, 2015 12:37 AM
Billy Decker
Sep 4, 2015 03:46 PM
