My car is possesed
Old Aug 18, 2003 | 09:50 PM
87cam305's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 305 (LG4)
My car is possesed
Tonight I was getting gas and I came up to a stop light and hit the turn signal (left one) and it flashes slowly as it always does then stops completly. I play with the turn signal swich and nothing changes I turn off my headlights still nothing I turn my headlights back on still nothing. next I turn off the turn signal then back on agen and it is barly blinking. The light changes so I start going and it blinking normaly. it worked fine the rest of the way home. BTW the right side worked fine the whole time. Any hints would be great.
Old Aug 18, 2003 | 11:23 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
a ghost! lol i sent him to see ya
i dont know...are all the bulbs in working condition outside the car?
Old Aug 19, 2003 | 09:29 AM
armac's Avatar
Car: 83 ta
check the ground at the body and socket itself along with the bulb, give them all a good cleaning and give it a shot. my 83 use to blink fine untill had the lights on and then nothing. turned out to be hte front turn singal ground wire was loose in the socket. also you might try your four ways and see what happens might help narrow down the problem. if it works fine with the four ways the switch might be bad. good luck!
Old Aug 19, 2003 | 04:02 PM
87cam305's Avatar
Engine: 305 (LG4)
Thanks I will check that out.
LOL :hail:
Old Aug 26, 2003 | 12:11 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
my friend had an integra before he got a real car. his right blinker blinked very fast for a while and i didn't know what the heck it was. when we changed the bulb it was back to normal, blinked normally and everything.
Old Aug 26, 2003 | 05:49 PM
badjuju342's Avatar
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
i'd check those grounds,armac is on to something. grounds make circuit do some pretty strange things when they are loose or corroded
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
