Radio display goes out when I step on the brake.
Old Sep 6, 2003 | 01:01 PM
macinmodesto's Avatar
I am having a mess of electrical issues.
1. The blinkers stopped blinking. When I turn the turn signal indicator, it's solid.
2. The cruise control stopped working.
3. When the car is completely off and I step on the brake, the tone box goes off.
4. The rear lights don't work EXCEPT when the hazard lights are on...then they flash.
What the heck is going on? I'm so confused. I don't even know where to start looking.
mac
Old Sep 6, 2003 | 06:37 PM
onebinky's Avatar
Pull down your little "convenience center". It sounds like you have a loose connection or a wire with no insulation touching ground when you hit the brake.
Old Sep 8, 2003 | 09:53 AM
Convenience Center
This is a 1989 RS...what would the convenience center look like? Appreciate the guidance...you guys have been very helpful...thanks!
jw
Old Sep 8, 2003 | 12:09 PM
onebinky's Avatar
To get to the convenience center, you have to pull off the plastic panel under the dash on the driver's side. It sits opposite the fuse box, right by the center console. It'll have a removable panel on the bottom of it to check the wires on the actual box, and it also has two tabs to push to swing it down and check the components.
You also didn't say if it is the factory radio. If it's aftermarket it could just be a crappy installation that is giving you issues. Maybe a loose wire or something
Good luck,
Matt
Old Sep 9, 2003 | 09:51 AM
radio
That's a good point. I should have mentioned that everything is factory. Nothing has been changed. I see the panel you discuss...I will start looking into it tonight...
jw
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
