Computer Replacement Help
Old Sep 9, 2003 | 03:18 PM
Layne's Avatar
Hey everyone, my computer is failing the 'wiggle test,' while it's hooked up but being tapped gently, the engine is shutting off.
My question is, should I replace it or perhaps only the PROM chip in it? How do I know if the PROM went bad and not the computer? DOes a new computer come with a prom?
My symptoms are rough driving, car idles really rough on EVERY stop light/traffic stop and almost shuts off.
Please help!!!!
Old Sep 9, 2003 | 04:42 PM
armac's Avatar
Car: 83 ta
replace ecm and the new does not come with a prom and needs to be transfered over to the new ecm
Old Sep 9, 2003 | 06:41 PM
STEVE OC's Avatar
Dead ECM
I had that very same problem . ECM no code 12 with engine at idle tap on side of ecm if engine rpm changes replace the unit
the mem cal will be ok . I spent hours looking for bad contacts [etc] but a new ECM fixed the problem Steve
Old Sep 10, 2003 | 10:02 PM
Layne's Avatar
Unfortunately, I STILL have the same problem, I'm getting to the point where I'm almost ready to redo the entire electrical in the car....can ANYONE Please help
Old Sep 10, 2003 | 10:35 PM
STEVE OC's Avatar
Have you replaced the ECM,if you have is it second hand or new
you may have another dud
Old Sep 11, 2003 | 09:11 PM
Layne's Avatar
New from Chevy themselves
Old Sep 11, 2003 | 10:53 PM
STEVE OC's Avatar
Make sure that the chip is locked in tight and both wiring looms are pluged in and making good contact if ok and the engine runs rough or changes tune when you tap the ECM it has to be in ECM internal circuit the same as mine was , if the car runs ok otherwise it wont be the chip
Out-Cast
Dec 31, 2015 04:40 PM
Bryan F
Aug 18, 2015 02:28 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
