hatch release wiring
Old Sep 12, 2003 | 03:36 PM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
I'm looking for the relay harness. I found the switch plug under the switch plate. I have the panel off on the passenger side and can see just about everything. Now where is this three pin relay harness?
Also, does anyone have a pinout of the switch connector? I'm not going to be using a factory switch.
Old Sep 13, 2003 | 01:59 PM
MechCD's Avatar
Engine: LO3, Vulcan
Anyone? Does anyone at least know where the relay is supposed to be? I'm getting a bit frustrated. The so called guide just says its under the passenger side and has an orange, brown, and black wire going to it. Thats all great and dandy except I don't know where to look.
Old Sep 13, 2003 | 04:10 PM
BIGJsTA's Avatar
err...Im not sure what your looking for...But if your talking about the relay to the hatch pull down motor, with black/orange/blue/brown wires, it's in the back, hanging right underneath the motor, behind the back panel in the hatch....Your looking for a relay up in the dash? Behind the switch? i dont think i have one there...
Old Sep 13, 2003 | 07:00 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
the hatch release switch relay is in the center consloe, if you remove the shifter plate you may be able to get to it, it in about 7 inches from the switch
Old Sep 14, 2003 | 06:57 PM
MechCD's Avatar
Engine: LO3, Vulcan
Exactly what I needed, thank you. For some reason the guide on this site says it is under the passenger side dash. Someone should edit that.
Street Lethal
Apr 30, 2019 12:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
neekolzun
Aug 24, 2015 04:59 PM
smooth
Aug 18, 2015 06:34 PM
stalkier
Aug 13, 2015 12:59 PM
