Who knows where to find the Relay for the door lock accuators??
Old Sep 16, 2003 | 01:06 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Someone mentioned before that when your door locks start getting "lazy" that it can sometimes be caused by the Relay going bad. My manual says its located LH shroud by the door grommet. Where is this??
Old Sep 16, 2003 | 02:47 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It's behind the kick panel beside the drivers left foot.
Pete
Old Sep 17, 2003 | 12:35 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
What about a 1991 Z-28? Where is the lock relay?
I know on the 82-89 model cars it is behind the driver kick panel, but where is it on a 1991 F-body?
Old Sep 17, 2003 | 02:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
same area only a little bit higher up above the hood release cable.
The Trickster!!!!!!!!!!!!!
Old Sep 18, 2003 | 03:24 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Anychance on someone taking a pic of the 1991 relay for the mentally impared?
THanks!
Old Sep 24, 2003 | 05:13 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
THanks!
The relay is a wide black rectangular box held onto teh car with 2 plastic prong style clips. If you look up the drivers side kick panel, about level with the lower dash, you should see it, it's the only relay up there I believe.
I'll take a pic of one I took the other day for you if you still can't find it.
Old Sep 30, 2003 | 11:31 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Ok, I removed the driverside kick panel and looked. It's not there!! I know it is located there on the 82-89 model F-body's, but it's gotta be somewhere else on a 90-92 F-body.
Can anyone help me!
Old Sep 30, 2003 | 12:35 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
On the early model camaro's and firebirds it was located at the lower cut-out behind the left kick panel. On the later model camaro's and firebirds it was relocated to a higher point above the hood release cable. I know it is there because I just removed one about three weeks ago. It is a black rectangular relay and is held to the sidewall by a slide post. Give me a few minutes to check on an old relay I have and I will give you the part # for it.
Old Sep 30, 2003 | 03:03 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Ok, the old ones are grounded by a ground strap (metal tab bolted to the inner kick panel metal).
Where and how is the newer style relay grounded?
Will re-grounding the newer style relay fix the lazy power locks?
Old Sep 30, 2003 | 06:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Ok 1bad91z, here is the part number for the door power lock relay that is supposed to be in your car, it is 12065122. I tried to include a schematic showing its location in your car. However, I ran into some difficulties in importing it into this post. Therefore I will send it to you in an e-mail in pdf format. Let me know if have any questions. Also when you say the door locks are lazy, what precisely do you mean. Are they slow, do they stick or seem to hang, is it both sides are just one?
I had planned to e-mail the schematic to you, but since your e-mail is disabled, I am unable to do this. Sorry!!!!!!!!!!!
The Trickster!!!!!!!!!!!!!!!!!!!!!!
Old Oct 1, 2003 | 06:22 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Trickster, you have a PM.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
g.l.mos
Aug 22, 2015 12:02 AM
