help with fuse blowing...
Old Sep 22, 2003 | 02:43 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
i keep blowing the 20amp acc fuse in the 84, even with a 25amp fuse in it, it blows within like 5-15 min, im gonna go check the radio wiring now for exposed wire, but aside from a wire grounding/shorting out by contact, what else could it be? Thanx.
Old Sep 25, 2003 | 12:40 AM
onebinky's Avatar
It has to be either a shorted wire, or the component is drawing way to much amperage. Nothing else could cause it. More likely than not, it is the exposed wire
Good luck,
Matt
Old Oct 29, 2010 | 03:24 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Re: help with fuse blowing...
cigarette lighter seems to pop the acc fuse. in my 89 the cigarette lighter was loose in the holder and it would jimmy its way down and make contact, after about 5 min it would pop the fuse cause it would heat up and there was nowhere for the current to go. so give that a check as well
Old Oct 29, 2010 | 03:26 PM
willexoIX's Avatar
wow, just now realized this thread was from 2003. lol
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
AmorgetRS
Sep 28, 2015 09:33 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
