Broken Tach
Old Oct 4, 2003 | 05:15 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Broken Tach
When I start my car at idle the tack sits at like 2500 rpms when I know thats not how high I am actually idleing. When I drive it ,the tach shoots up to like 4500 RPMs and increases from there. I have had people tell me mach tach needs recalobrated, If it is that how do I recalobrate it . I appreciate any input.Thanks
Old Oct 7, 2003 | 08:23 AM
Berlinetta's Avatar
my tach also does that but its hard to get an answer on that one. My old boss told me that there is an electrical component that all the gauges circuits are run through and that sometimes it goes bad and cause some of the gauge readings to be screwed up. But i have no idea what the part is called or where it is. Hopefully someone can help us out
Old Oct 7, 2003 | 08:57 AM
IROCaholic's Avatar
Car: 89 Camaro RS
A friend of mine just told me that he had the same problem, and that he just replace the tach with a junk yard one ,and now it works fine. So I will probably go to the junk yard and get one for like $5.
Old Oct 7, 2003 | 10:43 AM
slinkh's Avatar
I had the same problem with my tach. When I took it out I realized part of the circuit board was fried. I did the junkyard deal and got one for 10$ in perfect condition. Those Tachs cannot be recalibrated as far as know. They come calibrated from the factory for a 4,6 or 8 cylinder engine.
Old Oct 7, 2003 | 11:46 AM
Morley's Avatar
Your tach can be repaired, costs around $80-$90
http://dandmrestoration.home.mindspring.com/tacho.htm
http://www.tachman.com/
$750 L98
Feb 1, 2025 02:25 PM
sheachopper
Jul 31, 2019 11:27 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Eric-86sc
Sep 28, 2015 11:37 AM
