darn pop up head lights
Old Sep 22, 2003 | 05:33 PM
strokedtpi's Avatar
Car: 1990 Formula 350
Engine: 5.7
ok heres the deal ive got a 90 formula and sometimes when i turn on my lights they turn on but they dont come up but a few minutes later they sometimes will spring up. but the actual headlights do turn on they just dont come up. im wondering if this is an electrical problem somewhere or if there is another relay i dont knwo about...
note:both motors are good because sometiems they work just fine for days....and thy are new
any help would be great
thanks
Old Sep 22, 2003 | 07:02 PM
armac's Avatar
Car: 83 ta
headlight relay or switch itself most likely.
Old Sep 22, 2003 | 11:43 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The problem is the OEM bushings inside the large nylon gear have disintegrated. These were made of gel material. You can easily repair them using the TDS 209280 Deluxe Hedlight Repair Kit that I manufacture. Here is a link to the instructions I include with the kit.
Lon Salgren
Top-Down Solutions
Old Sep 23, 2003 | 02:45 PM
strokedtpi's Avatar
Engine: 5.7
lonsal could you please elaborate on this...are these bushing in the motors themselves...because im pretty sure they are both good. thanks
Old Sep 23, 2003 | 02:52 PM
lonsal's Avatar
Nope. They are inside the large nylon gear. They fill the space between the nylon gear and the 3-lobe cast zinc hub that is on the actuation shaft. The worm drive of the motor drives the outer teeth of the large nylon gear. The gear drives the hub which is on a shaft which attches to the arm which raises/lowers the headlight. When the OEM gel bushings go bad they crumble into a spoonful of chunks or powder (depending on how bad they are). At that point the gear will free-wheel on the hub and the hub won't be able to raise/lower the headlights properly. Sometimes the chunks will engage the hub and it will go up. Replace them with the precision-machined Delrin bushings in my kit and it will work every time. Make sense now?
Lon
Old Sep 23, 2003 | 02:54 PM
strokedtpi's Avatar
Engine: 5.7
i htink i get ya thanks a ton man
Old Oct 2, 2003 | 11:27 PM
strokedtpi's Avatar
Engine: 5.7
wheres this headlight relay located...is it near the headlights or.......??
Old Oct 7, 2003 | 02:58 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
The rebuild kit is great and if you have new motors you definately need to get two of the kits. One for each headlight. Worked great on mine which was doing the same thing as yours. Now they work perfectly.
RazorN8
Jan 7, 2022 11:44 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Omega
Aug 10, 2015 12:46 PM
