Could It BE Alternator?
Old Oct 5, 2003 | 12:17 AM
91zzzeder's Avatar
Car: 91 Z28 All Original
Engine: LB9
I've been having weird electrical things happening like my speedo works on and off,and the engine idles really high,low or fine.
I checked the ground wires but lately I noticed when driving at night the light will dim and my volt meter gauge will go down to 11-12 and then it will go back up to 13-14 volts and the lights will go bright. This happens maybe 5 times on a 15 minute drive.
Could it be the alternator or maybe a bad connection?
The car has 105kms and the alternator was replaced at 60kms.
Old Oct 5, 2003 | 08:34 PM
onebinky's Avatar
you really can't rely on the factory guages for much of anything. Verify it with a meter on the battery. With the car off, you should see 12.5v, and with it running you should see about 14.3. It could be quite a few things, and I don't think any of them would be related to the speedo. It could be the voltage regulator in the alternator going out, it could be a bad ground somewhere in the charging system, or a faulty connection maybe on the wire that carries the power away from the alternator or the 12+ terminal on the starter (the car's power feeds off that terminal).
Check out that stuff and let us know how it goes
Matt
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
