Why do my turn signals slow down/ speed up??
Old Oct 8, 2003 | 12:05 AM
Mr.84TransAmer's Avatar
Car: '84 Trans Am; '88 GTA
Engine: Vortec 355ci TPI
Transmission: TH-700R4
When my car is in drive and doing at least 15 mph my turn signals will blink at a decent rate. but whenever I slow down and idle they will become REALLLY SLOWWW. When I accelerate they speed up again. Personally, it's kind of a cool "feature", but this can't be normal. So what could be causing it?
My alternator tested good at autozone, and my battery was purchased a month ago (which did not fix this problem at all) to replace my fast-dying older battery. Any ideas?
Old Oct 8, 2003 | 12:49 AM
MrBill's Avatar
The AutoZone alt. test is meaningless. They don't put a load on it when they spin it up (didn't used to anyway, I don't know if that's changed or not).
Check the voltage output of your alternator yourself with a digital voltmeter at the battery. See how much of a voltage change you get at idle vs. higher RPM.
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
