Car not starting...maybe vats strikes again?
Old Oct 9, 2003 | 01:44 AM
need4speedb4c's Avatar
Aight,
Car started fine yesterday, today, won't star. Replaced starter, still won't start, won't even turn over. Checked battery, fine...Replaced the ingition switch...Same thing. What's the deal? I was doing some reading about people having the same prob because of the the vechicle anti theft system(vats) anyone know how to disable this?
-Mace
Old Oct 9, 2003 | 12:25 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
u can tell if u have vats by a security light on your dash cluster, and i tink a vats key is bigger on the end of it, what u do is take a multimeter, put one probe on each side of the key, and read what resistance u get, go to radioshack or other elec shop, get a resistor of same or very close resistance, find that wires that go to the ignition cylinder for the vats reader, and put the resistor inbetween those 2 wires, hope this helps
Old Oct 9, 2003 | 06:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey need4speedb4c,
Read the post that I made to 1987gta concerning this. Did you get the information that I e-mailed to you this morning?.
The Trickster!!!!!!!!!!!!
Old Oct 9, 2003 | 06:52 PM
Checked to see if it was the vats causing the prob, but it turned out it wasn't. The security light doesn't stay on anyway.
Thanks for the info though...Here is a list of the things I have checked.
replaced starter (was going bad anyway)
replaced ingition switch
cleaned off key
checked to see if it was being caused by VATS, wasn't the prob
checked to see if it was the neutral safey switch, didn't help
Checked battery, turned out ok
-Mace
Old Oct 9, 2003 | 07:04 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
could it be a fusible link somewhere?
Old Oct 9, 2003 | 08:13 PM
How do I check for a fusable link?
-Mace
Old Oct 9, 2003 | 08:45 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are you getting a click from the solenoid, have you checked the starter relay? Wiring to starter solenoid?
Just a couple of thoughts
Old Oct 11, 2003 | 06:16 PM
Liqued212's Avatar
Car: 91 Camaro RS
Engine: 305 Modded
Transmission: 700R4 B&M blue clutches
I got the same problem .. except atleast sometimes my starter siliniod at least clicks someimes .. but most of the time it wont do nothing and sometimes i mess with it and get it to start.. I was told there is a peice thats needs to be replaced when these symptoms happen but i dont know what peice ..
Old Oct 11, 2003 | 07:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Liquid212,
You have E-Mail!!!!!!!!!!!!
The Trickster!!!!!!!!!!!!!
Old Oct 13, 2003 | 05:58 PM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
Hey Trickster can you send it to me too.
Old Oct 19, 2003 | 08:09 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Greetings Supermaxxbasher,
You have two (2) e-mails. Sorry there're late!
The Trickster!!!!!!!!!!!!!!
Old Dec 2, 2003 | 08:33 PM
PILU's Avatar
Car: Firebird 89' and Formula 87
Engine: 2.8 l and 350 v8
Transmission: 2.8 Manual 5 speed and 5.7 manual 5 speed
I think Im having problem with VATS.
Old Dec 2, 2003 | 08:41 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey Pilu,
Give me about fifteen minutes and I will shoot it to you in the e-mail
The Trickster!!!!!!!!!!!!!!!!!!!!
Old Dec 2, 2003 | 08:49 PM
PILU's Avatar
thanks.
Old Dec 2, 2003 | 09:03 PM
PILU's Avatar
thanks.
Old Dec 2, 2003 | 09:06 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey Pilu,
I take it that you got the e-mail.
Old Dec 2, 2003 | 09:21 PM
PILU's Avatar
yes, I got It, thanks dude
Old Dec 4, 2003 | 07:25 PM
IrocZed's Avatar
On Probation
Car: 03 BMW Zed4, 87 Camaro IrocZed 305 TPI
Engine: 2.5 I6, 305 TPI V8
Transmission: 5 spd., T700R4
Greetings Trickster,
I am experiencing sporadic starting issues as well. Vader and others have helped a lot.
Can you possible send me an e-mail for the VATS and any suggestion you may have to :
seangohain@yahoo.com or sean_gohain@peoplesoft.com
Thanks so much
Old Dec 4, 2003 | 08:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Greetings IrocZed,
You have a Yahoo!!!!!!!!!!!!!
Old Dec 7, 2003 | 02:16 AM
IrocZed's Avatar
On Probation
Trickster,
Thank you so much for the VATS info. It seems it's either my alternato which is not recharging the battery hence not putting enough current to start the motor.
So now i am stuck as the starter is not going in the right way.
Regards Sean
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
djmarch
Aug 9, 2015 05:27 PM
