I Melted my Battery
Old Oct 10, 2003 | 11:43 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
I Melted my Battery
today i took my car for a drive for the first time since i built my new motor..aside from the normal smoke from the header paint burning and the lack of a clutch (another post) it was going ok...i make a right hand turn to go back to my hous and all the sudden like instantly, i loose all power...so i get off the side of the road and figure im gonna see my starter wire melted..i look under the car and there intact...i then look at the ignition wire on the MSD box and thats good...i finally look at the battery and as soon as i touched the positive termial (side mount) the entire terminal came out of the battery...i looked around closer and i saw the metal were the bolt goes into the terminal like pouring out..it go so hot that it melted the whole positive terminal out...
why did this happen?....i have an MSD 6AL and i hooked the big red wire to the battery + just like it says to...so why did it get so hot?...i remeber feeling my alternator before i drove it and it was very hot....
the belt goes over the top of the alt pully and around the PS pully the under the crank so it spins it clockwise correct?....
thanks guys
Rob
Old Oct 11, 2003 | 08:04 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
your alt might be overcharging(it is able to put out near 20v)
visaully check you connections, make sure no positive wires are grounded out, then install a new batt, start the car and check your voltage at the batt, it should be between 13.5v and 14.5v
Old Oct 11, 2003 | 02:47 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
i went today to have the ALT tested...and it failed due to no stator volts...so i get a new bat and ALT under warranty...and i go to put then in...as soon as i hook the battery i here this grinding type noise..so i go over the the passenger side and touch the battery terminal and look to see were its coming from...
i look down by the starter and i see that the main power wire (battery +) was melted to the header and the power wire was welded to the header tube...
Old Oct 11, 2003 | 04:49 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i think you just found it, but you have a major short.
trace it down before you connect the new battery.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
drumstixer
Sep 29, 2015 03:02 PM
wstephan96
Sep 25, 2015 04:28 PM
