starter elec. problems
Old Oct 12, 2003 | 12:21 PM
Liqued212's Avatar
Car: 91 Camaro RS
Engine: 305 Modded
Transmission: 700R4 B&M blue clutches
when i try to start my car the starter syliniod will just click or sometimes it does nothing .. but i can take a jumper wire from the starter wire to the battery and it will start fine ..i have a low voltage problem im guessing but whats causing it ? any ideas or suggestions would be great..
Old Oct 12, 2003 | 09:08 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Are you jumping it directly at the connection at the starter?
Sounds like a bad fusible link or bad cable, most likely the link though.
Matt
Old Oct 12, 2003 | 09:55 PM
onebinky's Avatar
Could also be a bad engine ground. I just had that exact problem today. My 6 guage cable between the neg. terminal and the bracket by the smog pump was all corroded, and the cable that connects the back of the head to the firewall came loose somehow. When I tried to start it, my starter would just click and then smoke would pour out from under the passenger side of the dash. It turns out that since the starter couldn't source a good chassis ground, it was trying to pull all that amperage through the 2 of the small 16awg "system grounds" on the ECM. The car still starts and runs fine after I fixed that stuff, but the check engine light comes on now. I guess that's a project for tomorrow...
Old Oct 13, 2003 | 08:41 AM
mr. listo's Avatar
Car: 1989 iroc-z
Engine: 350-5.7ltr
Transmission: 700r4 automatic
Had the same problem. Get your self a new solenoid or a complete new starter I think that will solve your problem.
Good Luck.
cool:
Old Oct 13, 2003 | 12:28 PM
Liqued212's Avatar
Car: 91 Camaro RS
Engine: 305 Modded
could anyone tell me what a fusible link looks like or where i could find one in my starter wiring .. so that way when i open the hood i can check everything at once cuse my shocks are out and i hate opening and closing my hood lol
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
