windows wen key on acc
Old Oct 15, 2003 | 12:47 PM
boussole's Avatar
Car: 91 ws6
Engine: ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
Transmission: TRANSMISSION, MAN 5 SPD, B0RG WARNE
Axle/Gears: AXLE REAR, 3.42 RATIO
I won’t to use my windows switch when key position is on acc Can a jumper be made or modify something
Old Oct 16, 2003 | 10:42 AM
deadtrend1's Avatar
Whats wrong with turning it to the IGN position?
Old Oct 16, 2003 | 07:00 PM
onebinky's Avatar
Yeah, you just have to find your window motor relay wires as they go through the kick panel, cut the 12+, and rewire them to the Accy. wire in the ignition harness. The accy. wire will be an orange 12awg wire. Make sure you put a fuse on that wire too, unless you want to start a fire.
But like deadtrend said, wouldn't it be easier just to turn the key forward to the run position?
Matt
Old Oct 17, 2003 | 04:38 PM
boussole's Avatar
Car: 91 ws6
I’m under the impression that each time one turns the key to ing the system shoot quantity of gas for starting ,and my radio antenna come back down ,inflate the bag, etc…wile parking and choing of sound, interior, trunk ,hood , etc… would prefer to live to acc
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
sahlomonic
Sep 20, 2015 07:15 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Gunsbee
Sep 7, 2015 07:10 PM
