Back-up lights not working
Old Oct 21, 2003 | 10:59 AM
Chuck's Avatar
Where would you look first for trouble with
back-up lights.
Suddenly quit.
Thanks!
Chuck
Old Oct 21, 2003 | 12:41 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
if it is a automatic i would check the shifter, it is possible that the switch came loose, and isnt aligned right, for manual im not sure on that one, check bulbs in the rear, see if they are burnt out, and i think there is a fuse in the fuse panel for em
Old Oct 21, 2003 | 04:21 PM
grndmasnightmar
Guest
Posts: n/a
under console
if automatic there will be a half moon shaped switch mounted to the floor about 5 inches long a plastic tang rides along the shifter and should move with the shifter. put your car in drive while holding the brake hard does it start? if it does it is a malfunctioning switch. if it does not you have to adjust your switch. if this is the case email me and i will tell u how to go about this. Goodluck
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
