heater problems
Old Oct 21, 2003 | 07:24 PM
next_level's Avatar
heater problems
it's an 85 firebird
the heater worked fine, i pulled the motor and tranny, put everything back and the blower motor wouldnt come on..i run strainght power to it an it works, i have power on one side of the fuse.then my test light broke, an i wanted to check to see if the relay was bad, so i kinda just halfassed it an jumped power past the realy, i got a spark, and heard a pop somewhere, and it wasnt the fuse...
was the relay the problem, but i just made another one?
Old Oct 22, 2003 | 09:07 AM
Liqued212's Avatar
Car: 91 Camaro RS
Engine: 305 Modded
Transmission: 700R4 B&M blue clutches
It could be a relay ...but more than likely id have to say a ground wire did you hook up all grounds?
Old Oct 22, 2003 | 12:50 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
I had a similar problem. Was a bad ground on the firewall for me.
Old Oct 22, 2003 | 03:45 PM
billhelton's Avatar
Car: 85 Sport Coupe
Engine: 355ci
Transmission: TH-350
I'm having the exact same problem under the same circumstances - pulled engine and tranny, now no heater or AC. I'm getting power to the relay. I've also got ground - ran a test light from ground on relay to orange on relay. However, no power on purple at relay (and obviously none at blower). The only ground I pulled off was the braided ground to engine block and it's replaced. Also power showing at relay should indicate good ground. Any ideas???
Is there a second relay somewhere?
Oh,yea, I checked the resistors also. They were good.
Old Oct 22, 2003 | 04:37 PM
next_level's Avatar
yep, that's the exact same problem...where are the resistors at, that's the only thing i havent checked....
maybe you should try just grounding it to the battery and see if it comes on...
wish i woulda thought about that before i did what i did
and what the hell was that pop i heard
Old Oct 22, 2003 | 05:31 PM
billhelton's Avatar
Car: 85 Sport Coupe
Engine: 355ci
I did run a second ground to the body but nothing still.
To find the resistors, just follow the four wire connector that has the purple wire. It will take you to the resistors. There are two small screws that hold it in place. It's a very basic resistor - three coils of different size wire. Check to see if they're burnt or broken. If not, there fine.
Don't know about the pop. I didn't hear one.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
