Fog lights
Old Oct 28, 2003 | 07:43 AM
hesgone2fast's Avatar
Car: 89 Trans Am GTA
Engine: 350 stock (big mods coming up)
Transmission: automatic for now (T56 coming)
Fog lights
When I press my switch inside the car, the light next to the switch comes on, but the lights won't work, I noticed one of my fog light doesn't have a bulb, might this be the cause because they don't work?
I connected a voltmeter to the conectors of the fog lights and I don't get anything.
Any ideas?
Old Oct 28, 2003 | 04:47 PM
Zig's Avatar
Zig
Car: 91 Z28 with 64,000 miles
The switch activates a relay. Sounds like it may be bad. Even with one lamp out, the other should light. You should be able to hear the relay click when you hit the switch. If not, that's your culprit.
Old Oct 28, 2003 | 07:56 PM
MdFormula350's Avatar
this diagram came in handy when i added stock foglights to my car.
Old Oct 28, 2003 | 08:46 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
On my 85 (don't know if they changed this nice feature later) the fog lights will NOT come on if the HI-beams are on. If you have them on w/ low beams, and turn on hi-beams, they go out.
Old Oct 29, 2003 | 02:51 AM
same for me, its normal. look at the diagram u can clearly see the highbeams / relay are directly connected to the foglights and make them turn off when the high beams are on.
Old Oct 29, 2003 | 08:33 AM
OK, thanks a lot for your help guys!
Now, where is this relay located?
Old Oct 29, 2003 | 11:41 AM
under fuse panel to the right of the fuse block, thats where mine was.
its alittle smaller than the fan relay size.
Old Oct 29, 2003 | 11:43 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Fog lights won't come on with high beams on any production car.
On 85s, the fog lights will ONLY come on with low beams. On 86+ cars, they will also come on with the parking lamps.
Old Oct 29, 2003 | 03:39 PM
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
True, true...........
Old Oct 29, 2003 | 06:44 PM
Does anyone know where the relay for the fog lights is??????
Old Oct 30, 2003 | 12:03 AM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
now, about that diagrm... I see how the realy is connected in to the hi/lo beam switch, but that diagram can't be right... it shows that when you turn on your lights you have a hot hitting the top pole of the energizer for the relay - coming out the other side, (dots being a junction) it would go to the high beam indicator and then ground, not to mention the brights would be on at all times.
If the tan wire coming out of the hi/lo switch were to one side of the relay and a ground on the other then I'd buy it... am I reading something wrong?
Old Oct 31, 2003 | 06:01 PM
I'm sorry, I didn't see that reply. Thanks a lot!
I'll post when I check it.
Old Oct 31, 2003 | 09:22 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
fog lights
Next question.....'90 Trans Am, pushing the button turns on the fog lights but they won't stay on and the relay does click.
It's mounted under the hood on the left side by the hinge.
Any ideas? Bad switch maybe?
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
