what is this Hacked?
Old Nov 1, 2003 | 01:22 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
is this normal from gm or is something funny going on here. notice the brown wire cut. and the brown wire connected to the black/white stripe, blue wire grounded to metal. looks kinda hacked up what is it doing? bough tthe car with quite a few demons in it. Thanks
Old Nov 1, 2003 | 03:22 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If that is a solid brown wire going into pin "A10" at the ECM, then it is the speed input wire. If it goes into pin "A2" it is for the air select valve controls If the black/white wire goes into pin "A11", "D1", or "D10" of the ECM, this is a ground wire.
The Trickster!!!!!!!!!!
Old Nov 1, 2003 | 04:36 PM
Morley's Avatar
I can tell you from my own wiring harness (85 TPI) that it isn't supposed to be like that. Someone has tampered with the wiring.
Check your wiring against this http://www.eecis.udel.edu/~davis/z28...ody-wiring.pdf and see if you can figure what goes where
ZZ3Astro
Aug 13, 2019 12:57 AM
2012sergen11
Oct 13, 2015 07:38 PM
z28joe2
Sep 28, 2015 05:54 PM
shanelique22
Sep 24, 2015 06:30 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
