How do I get the power windows down?
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
I took the doors off of my 86 trans am, and the power windows are stuck up.
I looked at the harness that comes out, and followed it to the fuse box. I hooked it up to a battery charger set of 6v, black/ground to ground, and an orange with to +, tried hitting the window switches...nothing. tried the same with the other wires...
does anyone know what to wires control the power windows?
thanks
thanks
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I'm not sure about the wire colors, but if you want to put the windows down, apply power to pin "A" of the window (drivers side, pin "B" passenger side) motor and ground. Or lay the doors on something high enough and close to the car, hook up the wiring harness to the window motor and the battery and use the window switches.
The Trickster!!!!!!!!!!!!!
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
therein lies the problem. i cut the harness to get the doors off.
i'm having problems finding a wiring diagram that'll tell me the colors i need to use.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Ok N8MAN1068,
I'm not sure about the wire colors on your model, but they should be about the same as mine. On the drivers side, you will need the brown wire and the black wire, passenger side will be the tan wire and the black wire. I noticed that in your first post you mentioned an orange wire. Look at your wire harness connectors. You will need to connect the wire for pin "A" & "B" on each one.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if it was me and i really wanted them down, id just pop the door panel off, and apply power directly to the motor...
*shrug*
*shrug*
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
i would take the doors off...but you know,....i'm just too lazy.
all i want them down for is to store them and sell 'em this spring.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
