How can I find a battery drain??
Old Nov 3, 2003 | 09:39 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Car will start fine for a week or 2 then sometimes my battery will be drained and won't start in the mornings. Battery has been tested and is fine. So I must have a drain somewhere. Whats the best method to use in order to find it??
Old Nov 3, 2003 | 11:22 AM
85TransAm406's Avatar
Car: 1985 Trans Am
disconnect the pos. lead on the battery. get a multimeter, set it to amps. put it in line with the + terminal and the battery cable (like an extension) . it will read how many amps the drain is. then start taking out fuses until the meter reads less, that's where your drain is.
Old Nov 3, 2003 | 02:18 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Or just remove the fuse and probe the contacts with the ammeter. That'll be a lot easier than pulling a fuse and running around to the front of the car to check the meter at the battery terminals.
Old Nov 3, 2003 | 02:23 PM
Car: 1985 Trans Am
that should work too, i just have a meter with 10 ft leads and alligator clips, i hate bending myself up under the dash to probe all the contacts.
Old Nov 7, 2003 | 03:02 PM
Marc 85Z28's Avatar
Don't have a multimeter/ammeter? A test light will work, and cheaply too. Disconnect either battery terminal and install the test light in series with the battery terminal. If the bulb lights, you have a draw. Pull fuses until light goes out. That will determine the circuit.
Frozer!!!
Jan 19, 2024 04:55 PM
GTAman
Mar 15, 2019 11:40 AM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 9, 2015 05:27 PM
