Hi beam indicator
Old Nov 3, 2003 | 07:31 PM
HB Z28's Avatar
Hi beam indicator
The high-beam indicator went out on the speedometer in my '87 Z-28. I'm looking to avoid pulling the whole gauge cluster out, can i reach this bulb if I pull the dash pad off? Or if I get the cluster covers off and get all the way to the gauges, what holds the speedometer in besides the cable, so I can maybe pull it out and change the bulb? Thanks
Old Nov 3, 2003 | 11:49 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you go that far, your 2 10 mm stamped nuts away from just removing the whole cluster which, is really your best bet to changing the bulb.
Removing the dashpad will not gain you access as far as I remember but, it's been awhile for taking a dashpad off too. It's nearly impossible as it is to release the speedo cable, even less odds of getting to the high beam bulb.
Elephantismo
Feb 13, 2019 12:51 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
327IROC85
Sep 23, 2015 12:11 AM
