car has mind of own
Old Nov 4, 2003 | 10:10 AM
MshBks's Avatar
Car: 86 F-Body SC
car has mind of own
Ok so here's whats going on...occasionly when I turn my car off, the 4-ways begin to flash along with my instrument lights flashing. And to top it off while its doing this the car wont start...so I wait for about 10-20 min and it starts...any ideas on what could be going on? Thanks Adam
Old Nov 5, 2003 | 08:49 PM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
Re: car has mind of own
You didn't happen to name you're car "Christine", did you???? LOL
Do you have an aftermarket alarm hooked up to you're car, cut off switch etc..?
Old Nov 7, 2003 | 12:06 AM
MshBks's Avatar
Car: 86 F-Body SC
LOL, no I didn't name my car christine...I don't believe my car has an alarm (if it does it doesn't work) On the under side of my dash (driver side) there is a little box no more than 2-3 inches long and inch wide and like and inch in depth, however it's just hanging and its wired up, and it flashes a little red light...just curious on what that could be
Old Nov 7, 2003 | 01:55 AM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
It's probably an aftermarket alarm. I would get rid of that thing fast. If that doesn't fix it, call the GHOSTBUSTERS!
Old Nov 7, 2003 | 02:34 AM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Maybe you should have :-)
Old Nov 7, 2003 | 10:22 AM
406-IROC's Avatar
Car: '86 Camaro
Axle/Gears: 3.45
That sounds like an alarm. Don't just cut it off, and don't start ripping wires.... let us know if it is wired through a thick yellow wire by the fuse-box (just under the steering column bracket bolts).
Azrael91966669
25
Jun 20, 2017 04:04 AM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kah992
Aug 19, 2015 02:55 PM
