Battery Gauge not functioning...
Old Nov 12, 2003 | 03:00 PM
StealthElephant's Avatar
Car: 87' Iroc
When I start my car and let it sit in idle at like 850RPM my battery reads a little over 13v at the terminals. My gauge reads like 11, it's in the middle between the 13 and 8 marks. Why is this? It used to be between 13 and 18 and now it sits low. Can the gauge be bad? How can I tell the alternator is running?
Old Nov 17, 2003 | 12:34 PM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
Re: Battery Gauge not functioning...
If the car starts right up and idles, and the battery doesn't need frequent re-charging, then the alternator is working properly. However, that is definitely a pretty low reading. How old is the alternator? Do you have an aftermarket volt gauge?
Am curious.... start the car, then disconnect the battery. Did the voltage go back up on the gauge? If it did, put it in gear, then turn on you're wipers. What does it read now? If it's still low, then it's prolly a slowly but surely failing alternator.
Old Nov 17, 2003 | 08:11 PM
Car: 87' Iroc
Stock 87 gauge cluster. Is it possible to damage a battery gauge? does it have a fuse?
Old Nov 17, 2003 | 09:11 PM
406-IROC's Avatar
Car: '86 Camaro
Axle/Gears: 3.45
There should be a fuse in the fusebox marked 'gauges' for it. I never had a damaged volt gauge, so I'm not sure what can happen to them over time....
You're best bet is to install a gauge pod (if you already don't have one), and get you're hands on an aftermarket 2" voltometer gauge. This will give you a better, and more accurate reading.
Old Nov 19, 2003 | 09:38 PM
Faded's Avatar
Car: '91 Firebird
Re: Re: Battery Gauge not functioning...
Umm, aren't voltage spikes bad?
Old Nov 19, 2003 | 09:57 PM
406-IROC's Avatar
Car: '86 Camaro
Axle/Gears: 3.45
Re: Re: Re: Battery Gauge not functioning...
'Voltage Spikes'???? 'Removing' the battery cables from a running engine won't cause that severe of a spike. Only when you 're-connect' the battery cables... in which the engine should be shut down.
Plus, he's not running an ECM or TPI, so what's the worst that can happen? A blown fuse, or fusible link?
Old Nov 20, 2003 | 08:58 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
he's not running an ECM or TPI, so what's the worst that can happen? A blown fuse, or fusible link? [/B]
Smoking the Alt voltage regulator or one of the diodes would be un-cool !!!
Adding another volt gage to your cockpit would also be dumb.(Unless you want to look like a rye_cer)
I would bet your gage is OK. You probobly have a bad connection in the wiring causing the supply voltage to drop down, or the "ground" supply to drift up above zero volts. The gage displays the voltage differance between the two.
Someone on this board had a problem with the connections on the dash circut board where the volt meter mounts.
Do you have a DVM for troubleshooting???
customblackbird
Oct 1, 2015 04:30 PM
Johnoooooo
Sep 22, 2015 08:55 AM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
gta892000
Sep 16, 2015 12:37 AM
