defroster hatch
Old Nov 12, 2003 | 08:38 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
defroster hatch
i am thinking of adding a power defroster to my car and i was wondering if the wiring for the hatch is already run with the rest of the wires to the back of the car ? or would i have to run a 12v wire to connect to the hatch ?
also i took off the panel on firebird where the switch would be if i had a button for the defroster and there are wires in there, would that be the wires for the defroster button ?
i can get a panel out of the junkyard with the defroster switch in it, and i can get teh whole hatch for like $20 so i was wondering if it was worth my time
i understand that the connecter on the drivers side is the 12v positive wire, and that the one on the pass. side is only a ground, but i was wondering if the wiring was already in teh car, even though it wasn't origonally equiped with a rear defroster.
Old Nov 12, 2003 | 09:04 PM
tstokka's Avatar
Car: 2- 1986 TA 1 t-top 1 hardtop
Engine: 305s
Transmission: autos
if the wires in the dash end in a 5 pin plug with pink/black, grey, lt. blue, purple/white, and black wires then yes the m are the ones for the switch.
at the rear there would be a purple/white wire on the left side that connects to the LH hatch support arm and then a wire going from the RH hatch support arm to ground.
Your going to need the hatch support arms as well as the window.
gook luck.
Old Nov 12, 2003 | 09:26 PM
Car: 91 formula
Transmission: t5
my hatch support arms already have the tabs on them for the connectors, should i be ok, or should i grab them off of the donor car as well
Old Nov 12, 2003 | 09:36 PM
tstokka's Avatar
Engine: 305s
Transmission: autos
you should be set then.
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
whibbs
Exterior Parts for Sale
Sep 28, 2015 07:53 PM
formula00ra
Sep 28, 2015 11:50 AM
scottmoyer
Sep 7, 2015 07:06 PM
