1986 firebird Temp gauge
Old Nov 15, 2003 | 04:49 PM
lighthorseozzy1's Avatar
Simple question: Does the temp gauge just push into slots or is there wires going to them?..I checked out a cluster from 1987 firebird and wanted to figure out, how the temp gauge came out and in that cluster, you just pull that gauge out and plug it back in..does this pertain to the 86 firebird as well??
Old Nov 17, 2003 | 08:11 AM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
Re: 1986 firebird Temp gauge
Are you trying to replace clusters from an 87, to an 86... or are you trying to add an aftermaket gauge to you're cluster?
The cluster has openings for connectors behind it, that allow the connectors from the harness to plug into it (by pushing the cluster forwards.)... but the actual cluster itself has a flat sheeting lying flat up against it on the back, with the leads on this sheeting going to their individual gauges.
The heavy wiring from the harness is behind the connectors, that's positioned/locked on the inner part of the dash....
BRoss99
Aug 10, 2025 05:08 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
