Trunk Release Problem?????
Old Nov 21, 2003 | 07:04 PM
simifast's Avatar
Car: 1991 Z-28 Convertible
I have a 1991 Z-28 Convertible and the battery keeps dying. I believe its in the trunk release motor possibly draining the battery. It also sometimes prevents me from popping the Toneau cover to fold up the top. I rigged it to work but the battery is still draining. How can I check to see if this is the problem and if so, where can I find a new or used motor assembly. PLease help, it's DRIVING ME CRAZY!!!!
Old Nov 29, 2003 | 01:04 AM
bytal's Avatar
Car: 88 Pontiac GTA
Engine: 5.0L
Transmission: Manual
what is your reasoning for thinking that the trunk release motor is to blame for killin your battery... does it just keep on going and goin and goin like the energizer bunny?
Old Nov 30, 2003 | 10:55 PM
onebinky's Avatar
first check and see if you actually have an amperage drain while the car is off and sitting. Could just be a bad cell in the battery, or it's just bad. To do that, disconnect the positive lead on the battery, and then take your multimeter clicked to the DC Amps setting and place one lead on the battery, and the other on the cable. Make sure the doors are closed, and the underhood light is off. If you are showing a draw, pull the hatch release fuse and do the same thing. If you don't have any more draw, that's your problem. If not, keep pulling fuses until you isolate the circuit. Once you have found the circuit, check all the components on that circuit individually until you find the problem.
Good luck
Old Dec 1, 2003 | 08:57 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if im not mistaken, theres a switch that the latch hits when its down.... if the latch doesnt hit that switch, it wont let you open the cover, and the motor will keep going..
athough i could be wrong, ive only messed with it once before...
Old Dec 1, 2003 | 02:10 PM
Fairly Strange's Avatar
Car: '89 Formula
Engine: 305 TBI
What MrDude_1 said.
Check the local "Pull-A-Parts".....and it may not be the switch, it may be the relay.(its' back there with the latch....at least it is on my '89 Firebird ).
NM
Old Dec 3, 2003 | 09:14 AM
Screamin'87GTA's Avatar
Car: Trans Am GTA
Transmission: Rebuilt 700r4 with stage 3
the motor for the hatch release is easy to unplug if you think thats your problem,
No one ever thinks about this!!
The Diodes in the alternator could be bad, causing the alternator to drain the battery, The local autozone could test that for you.
Old Dec 9, 2003 | 03:07 PM
simifast's Avatar
Thanks fellas. I think its the trunk release only because once when it was disconnected the battery was good(I thinK) I did replkace the battery and the same thing happened. I rigged the switch so I could open the toneau cover. That problem I did fix but the draining is still there. I will disconnect the battery and try the fuse thing. Thanks for that advice.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
