Set timing procedures
Old Dec 2, 2003 | 02:12 AM
87Formula356's Avatar
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
I have an 87 firbird formula with an 88 tpi 350 in it. i just put an msd distributor in and i wannt make sure i set the timing at least to factory specs if not tuned a bit. the problem is my servce manual is crap and i think was made in 85. cause there is only marginal supplemental info on my car. so i don't know if im supposed to disconect somthing or if i have some type of advance. it is a late model GM distributor with a dual connector coil. also for some reason the timing light refuses to fire, i went out and bought an inductive one, and that doesn't work either, or on my parents car, i hooked up the leads and attached the inductive lead, no light. can anyone help me with either of these problems? Especially the check timing procedure.
Old Dec 5, 2003 | 09:38 PM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...ing+timing+tpi
Old Dec 8, 2003 | 11:22 PM
Engine: 5.8Ltr 356
thanks, but i don't have a tan wire. everything says tan wire and 6 degrees. or check emission conrtol label. one thred has a 305 label. but i need to know what to dissconect on my dual connector coil distributor. or any other procedures. there are quite a few other similar threads. but i havn't found anything specific to my needs. 87 and later type distributor with dual connector coil. 350 tpi. not much info when i don't have a tan wire
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
