fan always runs
Old Dec 6, 2003 | 10:32 PM
89 305 Formula's Avatar
fan always runs
The fan runs the second i start the car and doesnt shut off untill i shut the car off, is there a way i can rig this upto a switch to turn it on when i want too and can i get a detailed description on how to doit. Thx
Old Dec 6, 2003 | 10:59 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Check the wiring to and from the fan motor. My fan did the same thing until I found out that the idiot prev owner of my car decided to run a "constant on" wire from the 12VDC input at the relay straight to the motor, which, since it was grounded right next to the batt (aftermarket connection?) completed the circuit and ran all the time, probably because he removed or broke the air dam off and couldn't find out why the engine was overheating.
Old Dec 7, 2003 | 03:09 PM
MdFormula350's Avatar
yeah sounds like the relay is being grounded, could be a broken fan switch (which was my case) it casued the relay to get power right when the ignition was on which would power the relay.
Old Dec 7, 2003 | 04:18 PM
3gc's Avatar
3gc
Car: Z28
I wired my fans for manual control by running a wire from the green and white wire on each relay, to rocker switches i have in the ashtray (i haven't made a plate for them yet but may end up putting it up on the overhead console.) On the other end of the switch i put a wire with a ring terminal on the end to ground.
The wiring at the relays
The switches
Old Dec 7, 2003 | 04:47 PM
thanks
thanks for the pictures, ill mess around with it later, kinda cold out and dont have a garage to work in right now will it hurt anything if it runs constantly for awhile?
Old Dec 7, 2003 | 05:32 PM
3gc's Avatar
3gc
Car: Z28
Only thing i can think of is that the engine may never reach operating temperature. And possibly shortening the life of the fan motors. Most likely won't have any long term negative effect though.
Old Dec 7, 2003 | 08:26 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
keeping the engine from reaching operating temps is horrible. may keep it in open loop operation, bad gas mileage, and performance will suffer.
Old Dec 7, 2003 | 08:27 PM
its really sluggish for about the first 10 min of driving it and having it running, it gets to about 180-190 degrees after about 15min. seems to run aight after its at that temp
Old Dec 9, 2003 | 12:06 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I had that problem and it turned out to be that my headers had melted my knock sensor (which was right below them). It could also be a bad bad relay or temperature sensor. I think I am going to put this argument to a rest by turning on my fans while the car is running and then use one of those thermometers that you point the laser at it and see how warm it is (coolant hoses, intake manifold, etc.). It'll give me something to do.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
