My Car's Many Problems...help?
Old Dec 5, 2003 | 12:19 PM
mellissalee03's Avatar
Car: 1982 Camaro Berlinetta
Engine: 5.0L V8
Hi everyone! I have a 1982 Camaro Berlinetta and it has so many problems, including:
~The "Check Engine" light comes on ALOT..I've been told not to worry about it.
~The wipers turn on but won't turn off untill I turn off the car.
~The wiper fluid doesn't come out (the container is full).
~The e-break doesn't work.
~Sometimes when I turn it sounds like my wheels are rubbing on the car...I was told my tires are too big.
~The speedometer has been broken for months
~The needle on my gas thing bounces so I'm never sure how I'm doing on gas
~The driver side door handle wiggles and the pin isn't connected on one side...looks like someone maybe tried to break in.
~When I go too fast my car starts to shake (when the speedometer worked it would shake around 70-75 mph).
~The timeing belt broke but has been fixed..and ever since, there's a clicking under the hood.
JEEZ....any have this many problems when the first had their car?? Any ideas on how much it could cost to fix most of this??
Old Dec 5, 2003 | 09:26 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
1. - Get a scan tool, or a paper clip - look up how to pull your SES codes - I would worry about it....
2. - your winshield washer pump is probably burned out - $20 part and an hour at most to replace
3. - Your tires probably suck - get a nice set of 4 tires that are the correct size for your car - this fixed my high-speed vibration
I've had my fair share of problems with camaros, you've got some work ahead of you!
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
