Gagues not working at all
Old Dec 19, 2003 | 07:27 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
My car got broken into over the summer and they messed up the steering column real bad, then yanked the radio out. It was still driveable but the gagues didnt work. My dad put a new column in last week off a 6 cyl. 92 RS, but he said they still wont work. Im going home tues so I'll be able to look at it and get more info, but is there anything blatently obvious that could be killin them? Fuse?
Thanks!
Old Dec 19, 2003 | 12:38 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
id say it could be a fuse, one quick thing i thought id point out though, a cluster from a v6 car in a v8 car will have a very inaccurate tach
Old Dec 19, 2003 | 01:44 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Still the stock cluster, just a different steering column. Thank *** for automatics anyways
Thanks for the help!
Old Dec 19, 2003 | 02:09 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
oops, my bad. I dont know if vats would have anything to do with it but aside from that the wire that powers the gauges (pink w/ black stripe) might be cut. Check fuses first though.
Old Dec 19, 2003 | 05:02 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, VATS would have nothing to do with the guages malfunctioning. The connectors in the back of the instrument panel may have been pulled loose or had a wire broken.
The Trickster!!!!!!!!!!!!!!
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
