Electric fuel pump relay?
Old Dec 30, 2003 | 04:14 PM
The gta master's Avatar
Car: Pontiac Transam Gta
Engine: L98 350
Transmission: Th700r4
Does anyone know where the electric fuel pump relay is on a 1989 pontiac transam GTA?:hail:
Old Dec 30, 2003 | 06:39 PM
MdFormula350's Avatar
usually where the circle is in the pic.
i think its the far left one.
Old Dec 31, 2003 | 06:41 AM
Engine: L98 350
Thanks.....wasnt where i thought it was...
Old Dec 31, 2003 | 07:01 AM
Engine: L98 350
there were two relays there but it wasnt any of those.
there was a different type of relay there that had some sort of bad wiring and that seem to be the one,it had a six pin rectangular connector not a six pin square...like the other two...
Old Dec 31, 2003 | 06:49 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
First off, what seems to be wrong with the relay?
Second, It happens to be one of those in that particular corner, but you can only tell through the wiring harness coloring: The relay has the following wiring colors:
2 orange wires
1 tan/white stripe
1 green/white stripe
and 1 black/white stripe
The wires are probably coated in grease, so they will need to be wiped off so you can tell what color they are. My guess is that maybe the one relay with the broken wiring is the one you seek.
Old Jan 1, 2004 | 06:44 AM
Engine: L98 350
There is nothing wrong with the relay...
I need to fit a mechanical fuel pump in order to run the 650 cfm holley....Other wise the pump will continue to pressurise the system causing mechanical pump failure or carb problems....
Old Jan 1, 2004 | 12:59 PM
Engine: 2.7L V6
Axle/Gears: 4.41
When you remove it, set it aside. GM uses that exact same relay for a lot of things that control the engine. You might need it sooner or later.
Old Jan 1, 2004 | 02:30 PM
Engine: L98 350
Will do...cheers for th advice........
Old Jan 24, 2004 | 01:27 PM
Engine: L98 350
OOPS!!
I have removed the fuel pump relay a month ago which stopped the system priming.....But now when i crank the engine for a second or two the fuel pump still kicks in and floods my nice new holley i have just fitted???
How come the stock tpi fuel pump is still working......I am hoping it has not damaged my mechancal fuel pump.....
How can i stop the fuel pump working ....why is it still working i have removed all the fuses other than the ecm fuse which i need to leave in due to the vat system......
i have a points distributer so thats not triggering the ecm.
i can still hear a click when the pump operates the click comes form behind the firewall and all relays near the brake booster are disconected...
Help!!!:lala:
Old Jan 24, 2004 | 02:02 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you were running a fuel injected system before, pull the two fuses for the fuel injectors at the fuse block. The fuse for the second bank of injectors also is the fuel pump fuse. It is labeled FP/INJ2.
The Trickster!!!!!!!!!!!!
Old Jan 24, 2004 | 03:08 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Along with tricksters advice, unplug the oil pressure switch above the oil filter. In the event the FP fails (or in your case, is gone), the oil pressure switch is a failsafe to keep the FP alive so you're not stranded. Once 5 or so psi is met, the switch closes and power is sent to the FP.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
