pmgr mini starter wiring
Old Jan 1, 2004 | 04:35 PM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
I am replacing my oem starter with a pmgr starter and wires are a ? mark.on pmgr there are 2 karge posts,1 with a wire that ohms out to starter case 000.1 ohm at the top of solenoid. the other is below that1 close to the starter case that does not ohm to case the small terminal is self explanetory but I do not care for putting bat cable on terminal that ohms to case.Any help would be appreciated......thanx
65panhed
Old Jan 1, 2004 | 05:57 PM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
starter wiring
I put 2+2 and got 5 starter wires go to bottom stud close to starter case wife did not push clutch in all the way works great..........
Old Jan 1, 2004 | 08:21 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
put all the big terminal wires on the stud that doesn't ohm to the case
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Wesly_66
Aug 26, 2015 09:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
milk
Aug 10, 2015 06:26 PM
