Who has a '91/92 with working 3rd brake light
Car: 1992 RS, F41
Seems nearly every one I see doesn't work, including mine. Not long after I get it working it vibrates loose again.
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
've got one in my 87 and it works great, I've had no problems with it. I am currently looking to upgrade it to a LED set-up, (along with my tailights) in the next couple months. I like the way the LEDs snap on and off, it looks better in my opinon, and they are much brighter.
Well, let's see.
We have owned the car for about 5 years, and have had it break 4 times already.
We have found 10 at the junk yards, with only 4 being in good shape!
So, we have replaced them 4 times already, and have just had it brake again just last week!
Damn stupid plastic !!
The CHP officer told us to replace it with a LED setup.
Like this helps,
George
Like this helps,
George
Car: 88 GTA
Engine: LT 1,
Transmission: TH700R4
GM third brake lights are always burning out.
usually at the socket.
You find out when you get pulled over or you ABS light turns on.
But will the LED lights work with ABS brakes the ABS controller monitors the third brake light just a ??? I dont know.
Car: 1992 Heritage Z28
Engine: 5.7l TPI
Transmission: A4
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
no thirdgens ever had ABS from the factory.
and there is no circuit on our cars that has a idiot light come on when a bulb burns out.
my usual check is pretty easy.... when stopped at a light, look into the chrome bumper of the fuggin SUV/truck behind you..... or back into a parkingspace infront of a glass front building and look at the reflection. :lala:
Car: 2000 Trans Am WS6 (Black)
leds
If you get the stock replacement LED bulbs.... DONT because they are so dim that you cannot even see the brake lights during the day.... I believe they do make a stock replacement bulb that is 35 bucks that is supposed to be as bright as our stock bulbs... but not worth it.
I'm gonna have to find a sucker to by $100 worth of tail/blinker/brake/sidemarker bulbs so that I can start my Led board tail lights...
-Steve
(Also I think the reason the bulbs don't work so well is because they only project light straight out the lense... they don't go into the reflectors)
-Steve
Car: 91 Camaro Vert
Re: leds
-Steve
-Steve
the problem is, theres one "cone" coming out of the top and a sharp cutoff of no light outside that cone... and then a mostly straight out beam around the flat edge
what you need, is motorcycle brake light LEDs... these are the ultra bright, wide angle LEDs that you see on the rear of some motorcycles.... they're the only place i know of where you know they will be bright enough and have a large viewing angle..
if i could find a commercial supplier that had the same specs, id buy from them, but i couldnt find one..... i ended up getting 10 off ebay... including the resistors already solderd and heatshrink wrapped on them for the 12-14.5V auto elec system..
go look for this guy on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2578978242
also, click that link and look at his pic... PERFECT picture of the way LEDs output light... i'll attach it here too
I've never had any problems in my '91. But I can't get those damned screws off the plastic. I wanted to fix my sagging headliner but that was in the way. I just hope it doesn't break or burn out anytime soon.
Car: '92 Firebird w/T-Tops Black w/Tan Interior
Engine: 305 TBI
Transmission: 5 Speed
I have a 1992 Firebird with the Brake Light mounted high on the rear hatch.
The bulb burnt out maybe 6 months after I bought the car. I replaced it and noticed a little while later that it was burnt out again. Upon inspection it wasn't actually burnt out.
I replaced it just in case and it still doesn't work. Every other light and function works on the car and no fuses are blown.
I have an electric meter but I don't know how to use it to test the socket for power. An auto-electric shop wants an arm and a leg to find out what's wrong and fix it.
Any Suggestions?
Any Suggestions?
Car: 91 Camaro Vert
Any Suggestions?
Any Suggestions?
take out the bulb
take some sandpaper and rub the corrosion off the contacts in the bulb socket
clean the bulb off for good measure
put it back together and check.
Engine: 305 TBI
Originally posted by MrDude_1
take out the bulb
take out the bulb
I haven't tested any of the connections to see if they are getting power when the brake is applied though. I have a meter but I don't know how to use it.
Is there a common problem these cars had with the light?
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The 92 hasn't worked in years. The bulb seems to get so hot it makes all the plastic brittle and break. Then it wont fit snug in the socket and the contacts dont make contact.
Car: 1992 Firebird
Engine: 3.1 V6
The third brake light of my car didn't work when I got it. If you unscrew the plastic trim marked in the pic you'll find a plug that connects the third brake light on the hatch to the car's wiring. It had come loose on my car.
mine wasn't working when i bought it. took it apart and saw that the reflector socket thing was cracked and not holding the bulb tight enough. got another one from a yard and fixed the problem.
and i agree LED's on the new cars do look cool.
that's my problem too....i can't get the bulb snug enough in the enclosure. it may work but as soon as i hit a bump it's done.
i've tried reinstalling different bases from other cars and it didn't help. if anyone has a better mount idea for the bulb please let me know as i'd like mine to work too.
Engine: 305 TBI
I took it all apart and in the process broke one of the tabs that hold the bulb in.
It still holds the bulb in but it is now cracked.I removed both of the contacts from the base and bent each one (very carefully) in towards each other. Not too much or the bulb wont slip in between them. This seems to hold the bulb better than the plastic does. If you rely on the contacts to hold the bulb then you don't have to worry about the plastic doing anything.
It seems to work pretty good for me. If the contacts are holding the bulb securely then you dont have to rely on the plastic. The plastic will just stop the bulb from falling all the way out.
well I was going to do a 3rd brake light mod wiht mine...decided against it due to it having this issue...and i jsut removed it....a friend of mine had this issue and he used some kind of bulb grease and used electrical tape to hold the bulb inplace...and his had worked excellently for about a year now....
Engine: 305 TBI
Originally posted by Farfire70
I had the same problem with my car when I bought it. I had the car inspected by a mechanic and he simply told me the rd brake light didn't work ( i assumed it was electrical). Well I took the cover off and the bulb fell in my hand. Just used a small screwdriver and bent the leads a little, holds in snug as a bug. Been going strong for 6 months now.
I think the reason a lot of them break is because they're on the hatch and are being continuously slammed down. I loe my car but we all have to realize that some of the parts aren't the best, plus they're 12-13 years old, it happens.
I want to figure out why my car leaks water down from the brake light if it rains heavily. It's usually only a drop or two here and there but still, there's electrical parts in there. For some reason I have a feeling is has something do to with the t-tops...
Car: 92 Camaro
My third brake light has burnt out several times. In fact, at one point the bulb was hot enough to burn the plastic lens (you can see it in the picture). I bought an led setup for it. So far it seems to be working. It was about 16 bucks for two at autozone. A little expensive for a bulb, but, if it works, its worth it.
Engine: 305 TBI
It might break because the hatch is slammed but the cause of the plastic becoming weak enough to break is due to the heating and cooling.
An LED bulb doesn't generate as much heat as a filament bulb. Switch it over and you won't burn your lense anymore.
www.superbrightleds.com has 3157's for much cheaper than 16 bux. 3-8 bux depending on the bulb. They have 12 and 20 leds per bulb and the 12 you can select wide or narrow projection. They also carry cool dome light leds as well as every other bulb for your car.
Engine: 305 TBI
is it a direct plug in? how do you modify it to work with the led?
Car: 1992 RS, F41
I figured I wasn't the only one with that problem since just about every 91/92 I see doesn't have a working brake light.
Mine works, but won't fit tight. I get it working and after I hit a couple bumps it's knocked loose again. Oh well, I dont' hardly drive the car anymore and now my odometer quit.
whoa... "fbody dude" those are the exact leds that I would NOT buy... you CANNOT see those during the day, at all... I've had people following me and tell me they had no Idea I was stopping, I've even had someone almost hit me because of these damned led bulbs... they are the same exact ones as superbrightleds.com... HORRIBLE!!!! its because our taillight lenses require light to be reflected back into the reflector like a flashlight, and these leds go straight out the back of the car... if you could rig up some sort of reflector to do that then more power to you, but until then these bulbs are crap, and cost about 25 times more than a standard bulb...
Just didn't want anyone getting excited about these piles of junk... in fact I now have to find some "sucker" to buy $75 worth of these "bulbs" because I have to put in either regular bulbs or some extravagant LED board set up... (might do the latter).
The only led bulbs I would recommend are the ones for the front side markers and the rear side markers, ONLY BECAUSE THEY ARE A PAIN IN THE *** TO REPLACE! They are not brighter, they do not look cooler, and they cost way more...
hope I saved you some money....
see how it only puts a little circle of light on the end of the lense... its WAY worse during any kind of daylight. I guess they look kinda cool at night but its not worth it.
Also the middle ones are amber because when I got that type of bulb Autozone didn't carry a red version...
Car: 2007 Infiniti G35 SEDAN
Engine: 306HP 3.5L V6
Transmission: Auto Pilot Baby!!!!
Axle/Gears: Don't care!
My 3rd Brake light was blown when I frst bought my car. After changing it over a year ago, it's worked just fine.
Car: '69 Camaro/'91 Camaro/'93 Camaro
Engine: 307/305/350 LT1
Transmission: Powerglide/Auto
My 3rd taillight on my '91 RS hasn't worked in a long time. Tried replacing the bulb one time but that didn't fix it.
Engine: 305 TBI
so you wear out your clutch instead of the brakes? seems like you'd rather replace 20 bucks in brake pads than to pay like 300+ to have the clutch replaced... or do the ***-awful job yourself... If I ever get a standard I will never slow down with the gears so that hopefully the clutch will last the life of the car.
Car: '91 Camaro RS
Engine: 305 TBI
I'm thinking of just using a 40mm computer fan, cutting a hole in the plastic under the light, and mount the fan with a grill on it. They run off of 12V, so just wire it into the light wiring, then it would turn on when the light does. This idea is still in the brainstorm stage, but I may go through with it in a week or so.
