O2 bank monitor methods
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Ok, I got an O2 sensor on either manifold, they are single wire sensors. Would any of you folks know how to use them to monitor oxygen content in real time??? I know it's a weird question, I just want to be able to monitor the info they are reading. Any suggestions will be appreciated. Thanks.
Car: 89 Camaro RS
Engine: 305 TBI
There are two type of O2 Sensor Gauges .. the one style is sold by Autometer (which shows a 20 led bar graph from Lean to rich), the other I can't remember but I think Jegs or Summit sells them. it shows a digital number display of the sensor reading.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
2 $2.99 LCD digital voltmeter, it an easy way to tap into any O2 sensor. Wire a lead into the car the next time you change them.
"Here is a general idea at what the O2 sensor voltage output looks like. As you can see, the slope around 400mv, which is 14.7:1, or perfect combustion, is very steep. This is why only computerized fuel injection systems can really hold anything close to 400mv. If you're wondering about how a sensor can read oxygen content in rich mixtures where there is no extra oxygen, the sensor begins to act as a temperature sensor above 400mv.
You just hook the positive to the wire and ground the ground.
A slick idea would be to take them apart and mount the LCD's neatly in the dash. hide the guts behind it. Its even tricker and most wont have a clue what they are doing.
or
http://www.autospeed.co.nz/cms/A_021...popularArticle
"You just hook the positive to the wire and ground the ground.
or
Elephantismo
Feb 13, 2019 12:51 AM
