Thirgen Tech Article Question, Headlights
Old Jan 26, 2004 | 07:58 AM
87Formula356's Avatar
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
I was reading the Tech. Article on how to re-wire your headlights.
i have a problem where 1 of my headlights keeps dimming intermittantly with high beams on or off. My question is, what do i ask for when i buy the relays mentioned in the tech article, is there some kind of serial number for that specific relay? or.... is there somthing else i can do to fix the dimming problem without re-wiring the whole system.
Old Jan 26, 2004 | 12:02 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
30 amp normally open relay
Old Jan 26, 2004 | 09:49 PM
Engine: 5.8Ltr 356
so it's a "Normal" relay? i can just ask for a 30 amp "normal relay" ?? i thought there were specific types?
Old Jan 27, 2004 | 09:16 AM
dankhound's Avatar
Car: 91 RS
normally open. That means its off unless you give it power.
Old Jan 27, 2004 | 05:48 PM
Engine: 5.8Ltr 356
thanks for the help guys, but im still kinda not gettin it, cause there are 4 prongs on the relay, and they have numbers like 86 and stuff, doesn't that fall under somthing specific?
Old Jan 28, 2004 | 11:12 AM
dankhound's Avatar
Car: 91 RS
The numbers just tell you which prongs are the coil side(control) and which side is the switched(high current).
specialized
Jun 18, 2022 09:26 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
