Bad computer???
Old Jan 27, 2004 | 01:51 PM
SgtSkip's Avatar
Bad computer???
Got a bit of a puzzler. I changed my oil and while ideling, looking for leaks, the engine stumbled a bit...just for a second. I noticed that the check engine light was on after that. When I tried to pull the codes, all I got was a constant check engine light. I also noticed that the usual cycling of the mixture solenoid before start up was missing. Think my computer died???
Old Jan 28, 2004 | 06:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If your ECM had died, you would not be able to pull up the code 12. Your problem lies elsewhere. Are you still able to crank the car and drive it?
The Trickster!!!!!!!!!!!!
Old Jan 28, 2004 | 06:52 PM
SgtSkip's Avatar
That's the problem. I can't pull ANY codes. It just stays lit. It runs fine but my gas mileage has definatly gone south.
Old Jan 28, 2004 | 07:45 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sorry SgtSkip,
My bad, I am sending you some information by e-mail that might help you. Granted that it is from a 1989 camaro service manual, but it describes the problem you are having with the check engine light.
Old Jan 28, 2004 | 07:55 PM
SgtSkip's Avatar
Too cool! Many thanks for the help. I have a computer from an 84 and thought about trying that out as well.
Semper Fi!
F.I. 57 Belair
Aug 23, 2021 01:09 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Johnoooooo
Sep 22, 2015 08:55 AM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
Stryker412
Sep 7, 2015 09:11 AM
