Purpose of this is??
Old Feb 3, 2004 | 03:41 PM
Hurin's Avatar
Car: '84 Z/28
Engine: l69
What is this? I tried tracing it down in my Chiltons manual, but to no avail. It has three wires heading out from it to in behind the far left side of the passenger firewall. The wires are colored white, maybe grey, white, again possibly grey, with a red stripe, and a red (I believe) wire.
Thanks, Bryan
Old Feb 3, 2004 | 03:42 PM
camarokev400's Avatar
looks like a map sensor
Old Feb 3, 2004 | 03:45 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am thinking the same thing.
Is there a nipple on the bottom of it for a vacuum line?
Old Feb 3, 2004 | 03:52 PM
yeah it should have a little rubber hose coming off of it leading to the intake somewhere....
Old Feb 3, 2004 | 03:58 PM
Hurin's Avatar
Car: '84 Z/28
Engine: l69
Yes there is a nipple, however it isn't hooked up. LoL. I didn't even notice it before.
Old Feb 3, 2004 | 04:01 PM
Zepher's Avatar
If you no longer have the stock Quadrajet on there, you wont' need that sensor.
Old Feb 3, 2004 | 06:31 PM
Hurin's Avatar
Car: '84 Z/28
Engine: l69
Alright. What if I am still running the cc quad? Would it cause like a rough idle or rich condition?
Old Feb 3, 2004 | 06:44 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If it is an 84 Z28 like he has posted in his sig., I doubt that its a MAP sensor. From the location and looks of it, that bracket looks like the one that the ignition coil would mount too if it had one and under that would be the EGR solenoid which would have two openings for vacuum lines and a nipple. Just a thought.
The Trickster!!!!!!!!!!!!!
Old Feb 3, 2004 | 09:50 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Weren't those the barometric sensors on the lg4's ?
Not sure of it's absolute function but, I know just looking at an lg4 the wrong way makes them run rough and rich.
Timing chain slack (80k+ miles) makes a huge differnce in idle quality (at least it did on my old camaro...).
Old Feb 4, 2004 | 05:12 PM
what color wires are leading to it? I am almost positive it is a map sensor.... what year is your car and what engine does it have?
Old Feb 4, 2004 | 05:19 PM
http://www.fbodymotorsports.com/inc/...l?v=1&pid=7552 It def looks like that to me
Old Feb 4, 2004 | 06:01 PM
Hurin's Avatar
Car: '84 Z/28
Engine: l69
The car is an '84 with the l69 (305HO). The wires leading it are a white possibly grey, another white maybe grey with a red stripe and a black wire. It also has a vacuum nipple on the bottom.
Old Feb 5, 2004 | 10:25 PM
84 Z28 5.0 HO's Avatar
Car: 84 Camaro Z28
Engine: 305 L69
Deadbirds is right, I have one on my L69. It is the barometric sensor. Ill check but i dont think that is a vac nipple I belive it is a port to check the barometric pressure of air
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
