Accel DFI ECM?
Old Feb 4, 2004 | 11:01 PM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
Accel DFI ECM?
I just installed the super ram on my 383 stroker but there is a problem. The ECM in the car (85 Z28) is stock and I won't get the most out of the setup witht the stock computer. I figure since I got the super ram I might as well go with something also made by Accel, but has anybody had any experience with the Accel ECM? If not, what else can I do? Thanks!
Old Feb 9, 2004 | 03:12 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
why not save yourself the cash and get into chip burning and roll your own chip for your setup? there's no better way. simply buying an aftermarket ECM won't get the most out of your setup either. you'll need to tune it as well.
Old Feb 10, 2004 | 12:42 PM
Car: 85 Z28
Engine: 383 Stroker
that would be alot cheaper, however I have no idea where to begin and I would probably just end up screwing it up real bad and I'd have to spend more money to fix my problem. Unless somebody wants to do it for me?!!?
Old Feb 10, 2004 | 02:15 PM
Mangus's Avatar
Transmission: T5WC
you'll have to tune any ECM you put in there anyway. With accel, you'll just be using their software. thats the only difference.
so either way you're going to have the same learning curve.
Old Feb 10, 2004 | 03:22 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The '85 ECM is MAF (Mass Air Flow) based, and maxes out @ 255 g/s, which is not enough for the 383 @ high rpm. Your best bet is to use a SD (speed density) system (I believe the Acell DFI is SD), which uses engine RPM and MAP (Manifold Absolute Pressure) to determine engine load. SD is more sensitive to engine modifications, once it has been tuned, since it is not measuring actual air flow, but is not limited by the MAF sensor maximum reading. The Accel DFI also has a wide band O2 sensor option available for real time afr correction. Another option would be to convert to a '90 - 92 SD system (7730 ECM) & use Tunercat & a PROM programmer & PROM eraser to tune the system.
Old Feb 10, 2004 | 03:27 PM
Mangus's Avatar
Transmission: T5WC
You have many options, and most of them are cheaper than the accel and offer exactly the same benefits (including WBO2). As well there are many ECM options, many programmer options, and many software options.
Investigate it. Battle through the learning curve. The rewards are great. And the pocket book impact is minimal.
Fanatic1074
Oct 3, 2022 05:57 AM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
efiguy
Sep 27, 2015 01:30 PM
