LED's
Old Feb 11, 2004 | 10:50 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
LED's
okay i ran a quick search and couldnt find what i was looking for nor did i feel like going through 800 pages worth of posts via everything the search button brought up.
What i want to do is remove my turn signals, and run ducting for air cooled front brakes from those holes. I want to run a low profile LED and i need a link to a company where i can buy yellow LED's from, they dont have to be crazy high quality the only reason im doing this is to keep the cops off my back. Also i dont know much about LED's would they sell the mounting brackets for them? or do you have to hook em up to your own board type thing. I'm just looking for something very low profile that will keep me out of trouble from the cops.
Old Feb 11, 2004 | 10:57 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I've done business with this company before
http://www.superbrightleds.com
good quality LED's and the price isn't that bad.
As for mounting brackets? I think you may have to fab up something yourself.
Old Feb 11, 2004 | 11:08 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
thanks for the link sonar, and i really ment to put this in the appearance and detailing forum i dont know how i ended up posting in here but if a moderator would like to move it i think thats where it should be
EDIT: also would someone care to explain the difference between the leds. That company lists their yellow leds at all different angles and lots of info that means nothing to me. What is an apropriate led for automotive use
Old Feb 12, 2004 | 01:34 AM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
the viewing angle is the amount of degrees from the front of the led, how far either way u can still see it good, after that it gets harder to see the light
Old Feb 12, 2004 | 06:46 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
To be specific, the viewing angle is the angle at which the light output drops to ½ of the rated output. A 10° angle will put out a tight beam of light, while a 30° will still be bright, but have a wider beam.
Old Feb 12, 2004 | 06:58 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Another option for an LED source: eLED.com
That's where I got all the LEDs for my taillights. You better know exactly what specs you need though....they have a HUGE selection (and very good prices.)
Old Feb 12, 2004 | 10:13 PM
Sonar_un's Avatar
Car: '86 T/A
wow! Love the tail lights
Old Feb 12, 2004 | 10:29 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
those are too fantastic honestly you have to be the most helpful third gen related person ive ever encountered on any board. How did you go about mounting the leds? i still have yet to figure out exactly how im going to do that
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
